£100 over budget
MeUK
Case STYLISH BLACK ALUMINIUM TRIGON CASE + 2 FRONT/SIDE USB (Special Offer)
Processor (CPU) AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3/)
Motherboard ASUS® M4A89TD PRO/USB3 : DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB ATI RADEON™ HD 5670 PCI EXPRESS - DirectX® 11
Memory - 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply & Case Cooling 600W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£59)
Processor Cooling COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£59)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT
This is my spec but it’s about £100 over my budget at £787.00. I really only have £650 to spend. What should I change?
I want a quiet gaming PC able to play the most up to date games. I use head phones so sound is unimportant.
Can you help?
Many thanks
Sleinous
Deffinatly the six core, way way unbalanced.
This would be a better spec for £650
AMD PHENOM II X4 955 (3.20GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB ATI RADEON™ HD 5770 PCI EXPRESS - DirectX® 11
Standard Build - Approximately 9 to 13 working days
Price: £658.00 including VAT and delivery.
This spec has a quad core Phenom, ample, a better GPU (5770), and a 64mb cached hard drive for £5 more than the 16mb cached harddrive you chose.
Hope that helps!
PCS
Administrator
Staff member
1. Change to 450W PSU.
2. Remove advanced cooling - go for standard cooler.
3. Select a cheaper case.
MeUK
I don't know if you are still keeping an eye on this thread but a question on the case
I expect to have to upgrade this PC in the future. When editing my spec in accordance with your suggestion a warning said the cpu cooler would not fit. Does the case you suggest have the room I need? would it be wise to go for a larger case?
I know this is difficult question but I would value your comments.
Phoenix
Select the Enigma case and not the trigon ;) now it fits. & yes, i moniter EVERYTHING mwhahaha ;)
I think you got that the wrong way around lol, and yeah it would be a better idea to to pick a slightly bigger case like the Elite310/Maelstorm/Trigon/Sileo(depending on budget) for future expandability.
Sleinous
Lol well what I mean is the 2nd one from the left, not the cheapest. & yes id go for the maelstrom
MeUK
Thanks for all your help I am ready to order.
Does anyone have a promotion code I could use?
PCS
Administrator
Staff member
Promotional codes are designed for tracking purposes. If you enter random codes, we can't track properly. Therefore we don't give them out.
MeUK
One of the good things about being indecisive is that one or two pay days have past. So this it, any last comments or tweaks please as I order tomorrow.
AMD PHENOM II X6 1075T (3.00GHz/9MB CACHE/AM3/) - BLACK EDITION
1GB AMD RADEON™ HD 6850 PCI EXPRESS - DirectX® 11, Eyefinity 3 Capable
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£76)
TV Card
PCTV SYSTEMS DVB-T DUAL TUNER DIGITAL FREEVIEW TV CARD
Surge Protection
Belkin 4 Socket 2M Surge Protector with £25,000 Protection! (Special Offer £6)
Miscellaneous
FREE STORMRISE Game (RRP: £29.99) with any AMD® Phenom™ II X6 Processor!
Price (excluding VAT)
£720.00
Price
£846.00
