Hey guys.
Can you review my build which I'm planning to order over the weekend. The budget is around £350 (will stretch if absolutely worth it). THe laptop will be used for non-intensive tasks (web browsing, writing up odd essay) (no gaming).
This is a custom Genesis V 15.6":
(not sure if link will work): https://www.pcspecialist.co.uk/quotes/893251/
Chassis & Display Genesis Series: 15.6" Matte HD LED 16:9 Widescreen (1366x768)
Processor (CPU): Intel® Pentium® Quad Core Processor N3700 (4 x 1.60GHz, 2.4GHz Turbo)
Memory (RAM): 8GB Kingston SODIMM DDR3 1600MHz (1 x 8GB)
Graphics Card: Integrated Intel® HD Graphics
Memory - Hard Disk: 120GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
2nd Hard Disk: 500GB SEAGATE HYBRID SSHD Drive, SATA 6 Gb/s, 64MB CACHE (5400 rpm)
mSATA/M.2 SSD Drive NONE
DVD/BLU-RAY Drive: 2nd/3rd HDD HARD DRIVE OPTICAL BAY CADDY (9.5mm)
£343 INC VAT
Everything else is default (I already have an OS so this is excluded).
Not sure about my Hard drive setup. I noticed there is an mSATA/M.2 SSD Drive option which may reduce costs/optimize performance but I don't really know what it does (I should really read into it!).
Also for a secondary drive is it worth getting an SSHD compared to normal SSD?
What would be your build for around £350 (less is better)
£343 INC VAT
