£500 PC - Basic Gaming
Cbarker
Hi all,
Looking to put together first order and am looking for a basic gaming pc. Nothing taxing but mostly strategy games like civ / aoe. Existing pc is 5 years old and on its last legs. Am not desperate for super high settings or playing the most demanding games, I have Xbox for shooters/skyrim etc.
I am not fussed about case Looks / monitors / accessories as it is plumbed in through my tv and have wireless keyboard/mouse.
Looking to spend around 500 but wouldn't go much above this spec as the max cost but wanted the expert opinions as to changes/modifications to it. I am not predicting I'll be replacing parts myself.
Will this do the job? What changes would you suggest?
Major questions were intel/amd to bring down cost?
Intel® Core™i3-2120 Dual Core (3.30GHz, 3MB Cache) + HD Graphics
ASUS® P8H61-MX: uATX, USB 3.0, SATA 3.0Gb/s
1GB AMD RADEON™ HD6670 - DVI,HDMI,VGA - DX® 11
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
Price: £541.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/C4MKOHj4xz/
Thanks in advance!!
If you are choosing the HD 6670 I'd consider the AMD A8-3850 APU since you can crossfire them.
AMD A8-3850 APU (2.9GHz, 4 Cores) & AMD Radeon™ HD 6550D Graphics
ASUS® F1A75-M: FM1 A-SERIES, SATA 6.0GB/s, USB 3.0
4GB SAMSUNG DUAL-DDR3 1333MHz (2 X 2GB)
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE AMD CPU COOLER (£19)
Price: £534.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-llano/V7WHhLVcdT/
Cbarker
Thanks.
I had read about cross firing - does this effectively happen when you have the components to do so or is this something that actively needs setting up?
Also - saw the 500gb wd drive instead of the 1tb non branded one. That's one thing I couldn't work out from reading other posts was how much hard drive quality affects performance?
is probably plenty but I saw cost difference on the unbranded and thought might as well.
I'd expect PCS to dispatch the system with crossfire enable, you could contact them for an official response. The caviar black is faster than the standard HDD you selected.
