£5k Budget for a pc gaming rig
Speedking
Already bought the monitor so 3.5k left
This is what I have so far.
I actually dont play too many games but when i do , i want it crisp.
FPS in the 3 figures if possible and am playing at about 6.2mil pixels on ultrawide 21:9
AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4) (Pre-Order Only)
Get FarCry 6 with select AMD Ryzen CPUs
10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP (Xmas delivery not guaranteed) (Pre-Order Only)
Get CoD:Cold War & 1YR GeForce Now w/ select RTX Graphics Cards
2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
I didn’t feel the need to make too many changes on this one, mainly tweaking the storage situation so you’ve got more super speedy goodness.
Also took the thermal paste off because the Corsair cooler (which I upped to the more appropriate H115i) comes with a high quality paste already pre-applied.
And I added the WiFi card that’s a bit quicker and has the built in Bluetooth. I run an Ethernet cable to mine but the Bluetooth is handy for my Xbox controller.
If you really wanted to go all out you could move the CPU up to the 5950X and the motherboard to the Crosshair. But that seems a bit overkill, you’d be better off spending the rest of the budget on games... or putting it towards VR kit 🤔
I really would’ve liked to have put this build in the Corsair 680x case but sadly it’s just gone out of stock again.
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP (Delivery before Xmas not guaranteed)
LED Lighting
2x 50cm ARGB LED Strip
Firefox™
Price: £3,002.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/dTN6nu0Mye/
Gavras
Master Poster
I would also have a serious look at the new AMD cards, they apparently give a performance boost when coupled with latest amd CPU’s
Speedking
LED Lighting
Firefox™
Thanks for that, i actually did make some of the changes ie the wifi card, you actually just reminded me to change it!
I would keep the RAM at 2x16GB 3200mhz, but other than that the spec from @AgentCooper is what I would go with :)
Given that RAM generally works better as a single pair and after reading what you wrote about the CAS latency giving no real difference between 3200MHz and 3600MHz I’m inclined to agree 👍
