The amount of VRAM needed really comes down to how many monitors you are using and at what resolutions. If you plan on having a multi-monitor setup or using a screen bigger than 27" with huge resolutions then go for the 2GB, if not the 1GB will be fine. VRAM doesn't stack either when using SLI.
Post your spec up if you want it looking over![]()
