TheUberMedic
Hi! Going to be ordering this laptop (hopefully) in 2 weeks so just getting a bit of info before I bite the bullet
So I plan to chuck out the HDD bay and small 46WHr battery and replace it with the 64WHr one and use the storage in my current laptop to power this one. Only problem is that since my current laptop is using a HDD, I gotta get a M.2 drive to transfer everything to it. So I have three options for choices: ADATA SU800, Intel 660p and ADATA SX6000 Pro.
The SX6000 Pro is £30 more than the SU800 but is PCIe (and after getting a SX8200 Pro as a boot drive, I LOVE that fast PCIe speed. Much better than that crappy DRAM-less SSD I had before) while the Intel 660p is only £1 more than the SU800 (strange pricing) and has PCIe speeds as well but after Linus' video on it, I'm a tad bit sceptical of it. Would I even notice the extra speed since this would be used to store my games on it? So should I stick to the SU800 with only SATA speeds, risk getting the 660p with potentially worse than HDD speeds or spend the extra £30 and get the SX6000 Pro? I could do a lot with £30
Also side note, what RAM does PCS use?
Code:
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
NONE
From 3 choices
2nd M.2 SSD Drive
NONE
Integrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor
1 x 230W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
Standard thermal paste
Bluetooth & Wireless
GIGABIT LAN & KILLER™ WIRELESS-AC 1550 M.2 GAMING 802.11AC + BLUETOOTH 5.0
PER-KEY RGB BACKLIT UK QUIET MECHANICAL KEYBOARD
NO RECOVERY MEDIA REQUIRED
Firefox™
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
