3.5mm audio jack is dead and bluetooth audio is choppy
amdkh
Hi.
I recently bought Tornado R5 gaming PC.
The problem is, when i connect my bluetooth headphones through bluetooth , the audio sound is very choppy, and there is constant audio loss which is very annoying. I have used several bluetooth headphones but the result is the same.
When I try to connect the headphones via an audio wire to avoid the wireless audio loss, it lead to another problem.
The 3.5 mm audio jack located at the top section of the PC, when tested, is not working. The one at the back works just fine though.
I need to find a slution for these problems bcoz I play my games at night and I cant disturb the household by using a speaker.
Thanks in advance.
