I last bought a new PC in 2020 from PCS (10900K /RTX 3090 system), and am looking to upgrade in the next few weeks. I have a budget up to about 6K or so, but I note a couple of items are not in stock currently, I just wonder if they're worth waiting for (9950X3D, and the ASUS TUF Geforce RTX 5090 (although you can pre-order). I mainly game in 4K and mod Skyrim/Fallout VR games (just upgraded to a Vive Pro 2).
I'm also not really up to date on which Motherboard I should be looking at - I want 3 M2 drives and a big SSD, but the more USB3 the better too.
For case I chose the Meshify 3XL after seeing reviews about how impressively quiet and cool it can be. Quiet is what i need when not gaming as it runs my living room entertainment too.
Edit: I play using a LG C1 4K OLED TV (120hz)
Here's the spec I am looking at, I'm grateful for any improvements you can throw my way:
FRACTAL MESHIFY 3 XL AMBIENCE PRO TG
Promotional Item
GIGABYTE X870E AORUS MASTER (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE RGB DDR5 6000MHz CL30 (2 x 32GB)
32GB ASUS TUF GEFORCE RTX 5090 GAMING - 2 x HDMI, 3 x DP
1TB SAMSUNG 9100 PRO M.2, PCIe 5.0 NVMe (up to 14,700MB/R, 13,300MB/W)
4TB SAMSUNG 9100 PRO M.2, PCIe 5.0 NVMe (up to 14,800MB/R, 13,400MB/W)
2TB SAMSUNG 990 EVO PLUS M.2, PCIe 4.0 & 5.0 NVMe (up to 7250MB/R, 6300MB/W)
8TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 1500W HXi SERIES™ ATX 3.1 & 5.1 PCIe MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
1 x 1.5 Metre IEC C19 UK Power Cable
CORSAIR ICUE LINK TITAN 360 RX LCD RGB HIGH PERFORMANCE CPU COOLER
ID-COOLING FROST X45 THERMAL PASTE APPLICATION
1 x 120mm Thermaltake TOUGHFAN 12 Case Fan
ONBOARD 2.5Gbe LAN PORT
2 PORT (1 x TYPE A, 1 x TYPE C) USB 10Gbps PCI-E CARD + STANDARD USB PORTS
Price: £5,787.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/aJkpqkSrjA/
Promotional Item
