Advice/suggestions
Hi, looking to get a PC and this is the build i have come up with so far looking for any suggestions or advice as I am quite new to gaming PC's. Its mainly going to be used for gaming and my budget is around £800 also would like some suggestions on future upgrade possibilities.
CORSAIR SPEC-04 MID TOWER GAMING CASE - BLACK/RED
Intel® Core™i5 Quad Core Processor i5-7400 (3.0GHz) 6MB Cache
ASUS® PRIME Z270-P: ATX, LGA1151, USB 3.0, SATA 6GBs
8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
1st Hard Disk
250GB Samsung 850 2.5" EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
FREE Assassin's Creed: Origins with select SAMSUNG SSDs!
NOT REQUIRED
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
INTEL STANDARD CPU COOLER
Price £820.00 including VAT and delivery
Gaming PC spec help
Hi, i have built this gaming PC and I am looking for any advice or suggestions. I intend to use this PC for gaming with titles such as PUBG and Battlefield 1 and my budget is around 800 any help would be appreciated.
Intel® Core™i5 Quad Core Processor i5-7500 (3.4GHz) 6MB Cache ()
1st Hard Disk
NOT REQUIRED
Monitor Cables
1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE
Price £840.00 including VAT and delivery
I would avoid the i5 7500 (and all the others) and go for an 8th Gen Intel system from here: https://www.pcspecialist.co.uk/computers/intel-z370-pc/
With an i5 8400 and its 6 cores ideally. Though if you got the i3 8100 it would still be as good as an i5 7500, with the option at least that you could potentially get an 8700k in the future. Not great value upgrading within the same CPU generation, but at least you have better options than with the H110M-R mobo.
You could drop the SSD in favour of an HDD. The SSD won't affect gaming performance, and you can add one as a DIY future upgrade more easily than having to replace the CPU (and mobo).
Intel® Core™i5 Six Core Processor i5-8400 (2.8GHz) 9MB Cache
ASUS® PRIME Z370-P: ATX, LGA1151, USB 3.0, SATA 6GBs
8GB Corsair VENGEANCE DDR4 2133MHz (1 x 8GB)
1[SUP]st[/SUP] Hard Disk
NOT REQUIRED
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
Price £827.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/tG8XwqBs9Q/
