After 6 years of waiting
A long journey has finally come to its final stages
Case STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-6500 (3.2GHz) 6MB Cache
Motherboard ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
Memory (RAM) 8GB HyperX FURY DDR4 2133MHz (2 x 4GB)
Graphics Card 2GB NVIDIA GEFORCE GTX 960 - DVI, HDMI, 3 x DP (Special!!)
1st Hard Disk 1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
Power Supply CORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Processor Cooling INTEL STANDARD CPU COOLER
Wireless/Wired Networking WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System NO OPERATING SYSTEM REQUIRED
DVD Recovery Media NO DVD RECOVERY MEDIA REQUIRED
Office Software NO OFFICE SOFTWARE
Monitor IIYAMA GE2488HS 24" Gaming Monitor
Warranty 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery 2 - 3 DAY DELIVERY TO REPUBLIC OF IRELAND
Build Time Standard Build - Approximately 10 to 12 working days
Promotional Item FREE INDIE GAMES [Dead by Daylight/Hard Reset] w/ GTX 950 & GTX 960 GPUs.
I have finally ordered my new PC.
I will post pictures as soon as I get it, very hyped.
Grats on your order:)
PCS should include the bits that come with the mobo including the disc with the drivers.
You may want to give some thought to a better case, something with 2 fans, as it will help keep your components cooler and quieter. I believe it's quite possible to amend orders if there are any tweaks you decide you fancy.
Also that case doesn't have front-facing USB 3 ports, so a better case would have that going for it too.
awesome, i have no money to upgrade the case so i'll have to live with it. i dont really care about usb 3.0 at the front as its not something i really need. hopefully my pc wont melt in this case then
steaky360
Actually quick question, does anyone know if my motherboard drivers will come on a CD with the PC?
thanks
As Oussebon said they will, however I'd strongly urge you to NOT use the CD unless absolutely necessary (the PC should boot fine without it) and check for the latest driver versions from the manufacturers website - so Asus for your mobo :)
Oh?
I thought once I finish installing my windows MOBO drivers are the most important ones aside from GPU for audio etc right, so will those just install automatically and all i'll have to really do is get GPU drivers? thanks
Oh?
I think what Steaky means is not to rely on the drivers on the CD as they'll be outdated. You'll need the latest drivers from the manufacturers website if they're not picked up by windows.
Oh alright, thanks for letting me know i've already found the drivers on the official website and saved them for the day.
quick question, is my wireless adapter just plug and play after i install those antennas (would have definitely forgot if I hadn't seen the amount of threads where people were told to put them on lol)? or must i get some drivers? thanks
UPDATE:
Processed Date 15-08-2016
Pre-Production Date 16-08-2016
Build Date 24-08-2016
Test Date 24-08-2016
QC Date 25-08-2016
Awaiting Dispatch Date 25-08-2016
Very impressed with build-time, expected to wait longer. It is now on the way to my house, extremely hyped now.
