Any recommendation where to buy graphic card online?
monteiro
Guys, my VGA card has come to an end after 6 years of hard work. I contacted technical support of PCSpecialist and they can only sell 1GB graphic card.
Does anyone could recommend any website to buy a new 4GB/6GB new pci express Graphic Card?
Thanks in advance guys. :)
Scoped Badger
Since this is a PCS forum, we can only advise on PCS builds.
If you're looking for something more specific, try Tom's Hardware, which is an open forum.
I think this is for a PCSpecialist build.
Can you post your full specs? Need to see what the other specs are.
What are you using the PC for? Why do you require the VRAM? If gaming, what resolution and refresh rate are you gaming at? PCS have plenty of GPU's in stock, not sure what you were asking for exactly?
monteiro
Im basically asking if anyone could recommend a website/store to buy here in the UK a new graphic card (description below) to replace my damaged one.
as I run some softwares to draw and render buildings, I need to keep to PC as fast as I can.
The full specs of my PC is (2014 built).
CORSAIR 230T COMPACT GAMING CASE - RED LED + SIDE WINDOW​
Intel® Core™i7 Quad Core Processor i7-4770k (3.5GHz) 8MB Cache​
ASUS® MAXIMUS VI HERO: PCI-e 3.0, SATA 3.0, USB3.0​
32GB KINGSTON HYPER-X BEAST DUAL-DDR3 2400MHz X.M.P (4 x 8GB KIT)​
4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready​
2nd Graphics Card
NONE​
3rd Graphics Card
NONE​
1st Hard Disk
1TB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)​
1st Hard Disk Partitions
350GB, 350GB, 300GB​
1TB SEAGATE ST1000DX001 1TB/8GB SSHD 64MB HYBRID DRIVE​
2nd Hard Disk Partitions
600GB, 400GB​
3rd Hard Disk
NONE​
4th Hard Disk
NONE​
RAID
NONE​
24x DUAL LAYER DVD WRITER ±R/±RW/RAM​
2nd DVD/BLU-RAY Drive
NONE​
NONE​
CORSAIR 750W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET​
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler​
monteiro
My friend, rendering with Lumion, V-ray, Mental ray + Revit, would be the NEED for a VRAM. Refresh rate I dont know. and I dont game.
Creating realistic images from a 3D model or even animation for a building/project.
Im considering to buy this one, just not sure what would be a good place to buy them
ASUS GeForce DUAL-GTX1060-O6G 6 GB Graphics Card - Silver​
I would just contact PCS and ask for an RTX3070 or 3080 depending on budget. Either will work with that PSU.
