Any recommendations regarding these specs?
amaban
COOLERMASTER MASTERBOX MB530P RGB GAMING CASE
AMD Ryzen 5 2600X Six Core CPU (3.6GHz-4.25GHz/19MB CACHE/AM4)
Gigabyte X470 AORUS Ultra Gaming: ATX, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2933MHz ~ (2 x 8GB)
8GB NVIDIA GEFORCE RTX 2080 - HDMI, 3x DP GeForce - RTX VR Ready!
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
NOT REQUIRED
WIRELESS 802.11 Gigabyte GC-WB1733D-I AC 1734Mbps + BT5 PCI-E CARD
2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
What’s it for?
What’s your max budget? What did the above build come to?
What monitor are you pairing it with? What resolution and refresh rate or make and model if you’re unsure?
amaban
Monitor i am thinking of is the Samsung LC27JG52QQUXEN, 144hz, 1440p
The PC is for gaming, like fortnite, apex, csgo for example
This build came to sround £1650
That is approximately my budget because the monitor is around pounds 250/300
Looks about perfect to me, I wouldn't change a thing.
The only thing I'd recommend is a minimum of silver warranty which is around £5
That's a sweet rig and a very good deal for that price. That'll push the monitor nicely.
