ArmourySwAgent & Armoury Socket Server
My new machine is requesting I allow the following apps to make changes to my device every time I boot up.
ArmourySWAgent
I run the machine in a standard account, so I expect it to ask permission to run administrator functions. I agree the changes, but it will ask me again next time I boot up the machine.
In Task Manager I am also seeing constantly high processor rates for Armoury Crate Service (22%) and ASI03 driver (4.5%).
My windows cursor has also started displaying the circling blue icon next to the pointer suggesting there was a lot of background activity.
These seemed to start when I agreed to a system prompt to run enhance Aura smoothing (I think). so I'm quite sure it's related to my exploration of the machine configurations
Anyone have any idea why this might be happening and how I might fix it.
Thanks in advance!
John
PC Configuration
CORSAIR 3000D AIRFLOW MID TOWER GAMING CASE| AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5)| ASUS® PRIME B650-PLUS (DDR5, USB 3.2, 6Gb/s) - ARGB Ready!| | 16GB Corsair VENGEANCE RGB DDR5 6000MHz (1 x 16GB)| INTEGRATED GRAPHICS ACCELERATOR (GPU)| 512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)| 1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW) !CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY| DeepCool AG400 Performance ARGB CPU Cooler| STANDARD THERMAL PASTE FOR SUFFICIENT COOLING|ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)| ONBOARD 2.5Gbe LAN PORT| WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0| MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS| Windows 11 Home 64 Bit
I would strongly suggest uninstalling armoury crate, it may well try to auto install in which case you have to disable it from the BIOS
Contrary to that video, you need to use an official method to properly uninstall crate:
