Hi there
Had my new pc from pcs for a while now. Just like to thank you guys at pcs for a fantastic service from start to end. Really appreciated knowing the status of the order as it went from stage to stage until finally dispatched. Excellent computer which suits my need for light surfing and moderate gaming.
Main Spec
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55 LX: USB 2.0 & SATA 3.0Gb/s, CrossFireX™ SUPPORT
4GB Corsair DUAL-DDR3 1333MHz
1GB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
600W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
There are a lot of settings in the bios which I want to tweak such as turning off the Asus Express Gate feature, setting the correct boot device priority and setting the correct dram frequency of my memmory to 1333 mhz (xmp)
I change the bios settings and press F10 to save them.
The next time the computer boots, it boots remembering the new bios settings, however 2 or more reboots later it always defaults to the basic bios settings.
Just a niggling problem at the moment but I like to tweak my computer to just the way I like it. Anyone else with the same motherboard had any similar problems with it?
Thanks for any advice you may give.
Main Spec
