Asus PN50 spec
Dandy Desmond
Hi all, i'm looking for a new desktop and am very tempted by a mini PC.
I am looking for a system that will run two, possibly three monitors with the main monitor being 4k. My usage is the normal email/browsing with some streaming. Any gaming I do is older games such as Age of Empires online so nothing too heavy, I have a console for more up to date games.
Will this configuration do the job? Any extra advice or tips, such as would I benefit from more, or faster, RAM. This is pretty much at the top of my budget but there is a bit of wiggle room. Also looking at a Beelink system from Amazon, it's cheaper but I like Asus gear and the PN50 has very good reviews.
Will be looking to run a soundbar (probably bluetooth) for some decent audio, what's the general recommendation of a decent choice for the configurable port on the rear?
ASUS Ultra Small Form Factor Case Ryzen 7 4700U/HDD (PN50-BBR049MD)
AMD Ryzen™ 7 8-Core Processor 4700U (2.0GHz, 4.1GHz Turbo)
PN50 Ultra Small Form Factor (HDMI/USB-C/DP1.4, USB 3.1)
8GB Corsair 2666MHz SODIMM DDR4 (1 x 8GB)
AMD® Radeon™ RX Vega 7 – 1,600 MHz
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
2 x USB 3.1 PORTS (Type C) + 3 x USB 3.1 PORTS
Price: £606.00 including VAT and Delivery
Dandy Desmond
Slight change. After reading up i'm thinking of swapping out this component
for a 512gb Intel 670p M.2 NVMe PCIe SSD as apparently M.2 offers far better performance. It changes the price to £614.
All looks good, the 4700U CPU is suprisingly capable given how little power it requires and the on board graphics are no slouch either.
Finding out the max resolution of the iGPU is surprisingly difficult, but I found quite a comprehensive table on wikipedia which hopefully is accurate and puts the max resolution at 7680×4320 @ 60 over 3 monitors.
4k is 3840 x 2160, so it's enough for 2 x 4k overall @60Hz
BUT, that unit only has 2 display outputs, one HDMI and one Display Port, so you'd be limited to 2 monitors.
8Gb RAM should be fine for your uses.
Definitely a good move on the M2 drive, they're significantly faster for only a little extra cost.
I'd up the warranty to silver for £5, increases the return to base costs to 1 year from 1 month.
Dandy Desmond
Many thanks for the reply. Will take your advice and up the warranty.
I'm a bit confused what you say about being limited to 2 monitors as Asus on their website say the PN50 can support up to 4 @ 4k resolution. There is a configurable port on the rear with an option of DisplayPort 1.4 or 1.2/VGA/LAN/COM I assume I get the choice from PCS when I checkout as to what to put in that port? The choice for an extra monitor would, I assume, be either DP1.4 or VGA.
I won't want 4 monitors, definitely 2 but probably 3 at some stage.
Ah, you're right, there is a third USB C with Display Port so you could use that as a third port, sorry, I missed that from the pictures.
The max resolution is dependent on the processors integrated graphics, has no relation to what the case can do.
Jasontvnd
It looks like Vega 7 can support 4 x 4k monitors surprisingly at least that's what I found online.
That's on the die itself ofcourse so need to check if the pn50 supports 4 monitors.
Looks like with a splitter display port 1.4 can support 3 x 1080p monitors right off the type C.
