BIOS update not recognised
I'm trying to update my Asus Prime A320M-K Bios, 4011 from 2018, but it tells me that PRO320MK.CAP is not a proper BIOS. Any idea where I'm going wrong? Thanks.
AMD Ryzen 5 2400G Quad Core CPU with Vega Graphics (3.6GHz-3.9GHz/6MB CACHE/AM4)
ASUS® PRIME A320M-K: Micro-ATX, AM4, USB 3.0, 6GB/s
8GB Corsair VENGEANCE DDR4 2400MHz (1 x 8GB)
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
STANDARD AMD CPU COOLER
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Microsoft® Edge
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-home-office/5tUKzaCXBz/
Is ”PRO320MK.CAP” correct, or just a typo, as the manual says it should be “PRA320MK.CAP”.
Is this a pcspecialist system? Can you post your full specs from the order page?
What method are you using to update it and why are you flashing such an old BIOS image?
Also, you can't downgrade a BIOS, you can only upgrade, so if that's older than the one you currently have installed, it's not going to work.
If you are trying to downgrade, why is that?
Again, without knowing how you're applying the BIOS, it's difficult to give any advice.
Not that I've done it but I know on my ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready! motherboard, there's a specific USB port you need to use
That's why we need to know if they're using the windows software or attempting it via the BIOS update as they're 2 very different processes with different criteria
