BSOD when gaming
carlos726811
Hi all. Was wondering if someone got some advice/help please. When i am trying to game i keep getting BSOD. The error code is Memory_Mangement.
I have all the windows etc upto date. as i always keep on top of them. See specs below
CaseCORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive1TB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 4400MB/W)
2nd M.2 SSD Drive1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
LED Lighting2x 50cm RGB LED Strip
Wireless Network Card10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
Can you post a screenshot of your optional updates page?
Have you got any software like afterburner or precisionX installed? Or Ryzen Master?
carlos726811
I have afterburner installed and AMD Ryzen Master.
carlos726811
I was just going to run Windows Memory Diagnostic see if that picked anything up. But i thought i would make a post 1st.
B4zookaw
Run memtest and see if it throws any errors. If it doesn't, I'd suggest a clean install of Windows would be the quickest potential solution
