Can anyone please check my spec
m_alek
Do I need extra fans?
Planning to use with 2 monitors. Should work fine with GIGABYTE Z690 UD?
Intel® Core™ i7 12-Core Processor i7-12700K (3.6GHz) 25MB Cache
GIGABYTE Z690 UD (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair VENGEANCE DDR5 5200MHz (2 x 16GB)
PCS FrostFlow 200 Series High Performance CPU Cooler
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Steveyg
What exactly is this machine going to be used for?
The main sticking point to me is the power supply which is incredibly underpowered specially if you plan to add a GPU to this it just wont have enough juice
Personally not a fan of Gigabyte boards they don't have the same quality as the ASUS boards in my opinion. I have a dozen or so PCS computers here in the office and the only one with a Gigabyte board seems to give us the most issues. CMOS needs reset every couple of months for example or it gives RTC errors on start up
m_alek
Hey, thanks for your reply.
I ll be using this for software development. Not planning to add a GPU.
I just want it to be as fast as possible, work with 2 monitors and be quiet.
