Can I fit another M.2 SSD into my PC, and how would I do this?
helloiamjack
Hi folks and thanks for reading, I'm looking to purchase a second internal SSD card for a PC build I purchased from PC Specialist a good 4 or 5 years ago now. Before getting into this, I'm (ashamedly) unfamiliar with the inside of the PC, so apologies if I ask a silly question:
Can I install a second SSD? My current one is only around 112 gb and has my C Drive installed on it and I have no idea if I would have the correct ports and wires available to fit a second one. I will attach some pictures of the inside of my PC, as well as the specifications of my PC. I believe (with my limited knowledge) that the current one is attached to my motherboard under some casing - would a new one be ok plugged in and placed inside my pc, or would I have to attach it to anything? If somebody could explain the process then I'd love to buy one and install it myself.
Thank you
FRACTAL FOCUS G BLACK GAMING CASE (Window)
Promotional Item
Get Just Cause 4, PUBG & More w/ select Intel CPUs!
Intel® Core™ i7 Quad Core Processor i7-7740X (4.3GHz) 8MB Cache
ASUS® PRIME X299-A: ATX, USB 3.1, SATA 6 GB/s, RGB Ready
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 1660 Ti - HDMI, DP - GeForce GTX VR Ready!
128GB M.2 2280, SATA 6Gb/s (560MB/R, 467MB/W)
Corsair H55 Hydro Series High Performance CPU Cooler
Microsoft® Edge
Welcome Book
That board has 2 m.2 sockets...one horizontal, and one vertical...
I'd assume the original m.2 is in the m2_1 slot at the bottom, and that will be under the metal cooling plate to the right of the CMOS battery.
You can either replace your current one with a single bigger, faster one, or simply add a second to the 2nd slot. However, a 128GB boot/app drive is very small by today's standards, a SATA SSD is very slow by today's standard, and SSD performance tends to degrade once they hit 50% capacity.
A new 1TB SSD with about 10x the performance can be had for less than £50 now, for example:
You could also take the opportunity to do a clean install of Windows to get a 'like-new' experience, and then copy over any documents you have on the old one.
BTW, if you're thinking of using the 2nd, vertical slot, then here's some video instructions...although you'd have to find the hardware if it's not already fitted...
B4zookaw
Never heard of a vertical mounted M.2 until now, interesting.
Your wifi card is unplugged btw, but you're probably not using it.
helloiamjack
Amazing, thank you for the response, so helpful! I’ve ordered the SDD you recommended, the 2tb one and will be fitting it (or attempting to) once I’m home this evening. Really appreciate the info.
