Case question
xuiton
Hello first of all
I will be soon purchasing a gaming rig from here with the OC i7 930 and gtx 480 but I was wondering if using the T900 would be ok, it seems to have large fans attached to it. However, does this make it really noisy? Is the standard elite 310 not suitable for this set up?
Thanks.
Gorman
Airflow is better in the Maelstrom (because its full of holes) and the Elite looks better in my opinion.
For silence i would go for the sileo, despite common grumplings i never had any heat issues with it.
xuiton
Thanks, the sileo doesn't seem to be an option though. So the elite will have no problem with airflow then?
Gorman
Its more of a closed box but has all the needed vents etc, i cant see it being an issue.
As long as you position it correctly :p
