Check this spec
MarkBartram733
Hi All, I'm looking at getting a new desktop to run Twinmotion and 3ds Max for rendering and animation. Could anyone let me know if this spec is up to the job please. Always grateful for a second opinion.
Promotional Item
Get Monster Hunter: Wilds with select AMD Ryzen™ Processors!
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
ASUS® ProArt X870E-CREATOR WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7, 1 x 10GbE)
64GB Corsair VENGEANCE DDR5 5200MHz CL40 (2 x 32GB)
16GB ZOTAC GEFORCE RTX 5080 SOLID CORE OC - HDMI, 3 x DP
CORSAIR ICUE LINK TITAN 280 RX RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
I would adjust the RAM and the PSU, rest looks good.
Do you need Windows Pro? Not sure if you're just picking it as it's Pro, just in case you don't need the features.
If you share the link in your quote it will make it easier for anyone to assist/feedback.
There's a how-to link within the thread below for guidance if if helps :)
