Comments welcome
pierre76
I need a new PC for desktop activities and mid level gaming, any comments on the spec listed would be welcome as it is not yet ordered. I have 16GB (2 X 8GB) of DDR4 3000MHz memory and a graphic card, which draws 150W, to be installed when the PC arrives
umm I think you forgot something, while you work out what give this a read and answer the questions it raises
These forums are for PCSpecialist systems only, they're full systems, you can order without GPU, but not without RAM
What make and model GPU do you have speciifically?
pierre76
Specs: Corsair Carbide 200R C Gaming Compact Gaming Case, i5-13600 Cpu, Asus Tuf Gaming Z690-Plus WiFi D4 Motherboard, 4GB DDR4 2666MHz RAM, Intergrated Graphics (GPU), 1TB PCIe M.2 SSD (3000 MB/R, 2900MB/W), Corsair 450w CVSeries cv-450 PSU, Frostflow 100RGB V3 CPU Cooler, Onboard Sound, 10/100 1000 Gigabyte Lan Port Network Card, Windows 11 Home 64 Bit.
I have a monitor as well as the items previously listed
Robbie
Thanks but for some reason my PC spec is not showing, so I shall have to have faith in my spec and order
I really would urge you to double check on here first! So many people regret not checking first, as there's always room for improvement especially when making a big purchase like this. The guides are really simple to follow if you read through them.
