NileyCoyote
Will the stock cooler be enough? Or would people recommended upgrading on that?
Building my first pc so finding some things a bit challenging!
I am ordering a pc specialist build. Just unsure what parts to upgrade and stay within budget. Posted the bones of my build below, had to basically choose between upgrading the cpu or going for the 3070 for now, so went with the gpu. Was just looking for some other potential upgrades/changesAs this is a dedicated forum for PC specialist potential customers/customers we are unable tocomment on self builds, you might have better luck on an open forum such as toms hardware
They're actually pretty helpful, thanks.If you post the full spec as described here, then we can take a look, the second link might be worth a look as well
How to Post Your Specification to the Forum - Check this Spec
When creating a forum post looking to discuss a PC spec there's a really simple way to post the spec in question here. IF YOU HAVEN'T ORDERED ONE YET AND ARE LOOKING FOR ADVICE ON A BUILD follow this step. IF YOU HAVE ALREADY ORDERED AND ARE ASKED FOR SPECS follow the next post. Click the...www.pcspecialist.co.uk
Please read before posting:- Collaboration of Helpful Hints
NB: These forums are not an official support channel. None of us work for PCS, we're all either customers or techies who just like to help out where possible. For any official support, you need to contact PCS directly either through your PCS account, or via the contact details on the main...www.pcspecialist.co.uk
