DDR4 or DDR5?
PeteWhite67
Hi All,
I'm currently speccing up an new desktop pc mainly for gaming (Starfield/Flight Sim/Battlefield) I've got most of the components sorted but was wondering whether or not the jump to DDR5 was worth it... yet.
I am considering 32GB (2 x 16) of DDR4 3600 or 32GB (2 x 16) of DDR5 6000. Obviously the motherboard will be different, but the price difference is just £65 which works out at under 2% increase DDR4 (£3,336) to DDR5 (£,3,401).
I've looked at some Youtube videos but there doesn't appear to be a clear winner.
Any advice would be gratefully received.
Cheers,
Pete
Hi All,
Cheers,
Pete
It's not so much the speed performance of the RAM but the future compatibility of the platform.
Intel are a dead option, their current chipset is done so won't support any future chips.
AMD AM5 is on its first gen and has support through to the end of 2025, so will support at least 3 more generations.
On AMD it only supports DDR5
Homer J
@SpyderTracks - Just wanted to check in and make sure you’re okay after having what appeared to be a violent seizure whilst typing.
perhaps spyder meant conspiracy and now one of those tin foil people
Tin Foil GIF - - Descubre & Comparte GIFs
Android typing just sucks compared to Apple, I've tried loads of different keyboards and none of them are very good, plus the screen is so oversensitive that it just adds what it wants most of the time
Ahh, so you were going with Intel.
Fair enough if you're sorted. I would definitely have another re-visit with AMD as the platform though :)
