Decent fan laptop cooler
Clintster
Can anyone recommend a decent fan laptop cooler that has a closed in base instead of the stand off feet they all seem to have?
These ones are useless if you want the laptop on your lap.
It needs to have a solid base and draw air in from the sides.
I have one of these on my non gaming laptop https://www.amazon.co.uk/Targus-Cooling-Lightweight-17-Inch-AWE55GL/dp/B07V4GTT81/?th=1 but it's getting a bit tatty now, It has two fans but there seems to be room for another two below those so I'm thinking of getting another and taking the two fans from the tatty one and adding them, then adding foam around the top so the air is forced into the laptop.
