Very happy about my new laptop, is truly a beast in games, the 144 Hz panel is really awesome compared to my ex laptop display 720p with 60hz...
-The display is absolute gorgeous compared to the ex 720p display from Asus, the view angles are very good no complain + thanks to the 30 days dead pixel guarantee there is no defect.
-17.3 and 1080p is definitely the best for a gaming laptop, wish i had this about 4 years ago when i bought my first entry gaming laptop with a gtx 850m and a i5 4200hq.
-The speakers are quite impressive for a laptop
-Can't see too much difference from the nvme compared to my ex SSD Samsung 860.
-GTX 1070 for 1080p maybe a little overkill but need those fps for the 144 hz display.
-The keyboard is very nice to touch and responsive and the lights look nice, would be nice if the RGB per key would be available to this model too just to show off for friends
i personal use a mechanical RGB per key keyboard so the laptop keyboard is used only for office work/internet surfing.
-The Control Center application should have a option for CPU scaling frequency because of the heat problem which i will describe in the following lines.
My only concern now are the temps for GPU and CPU. After 1 hour of gaming with medium settings to get those fps in FPS(PUBG&Fortnite) the CPU had 85 C and GPU 71 C with the COOLER MASTER MASTERGEL, i know those are normal temps but the laptop was on a cooler pad , now i ordered a better cooling pad with 115 CFM aluminium chassis , hope those temps get down, otherwise is kinda bad but it would be cool to have the option in BIOS to undervoltage or set the frequency lower for the CPU to keep it a little cooler , in my opinion 3,6 GHz are enough for a good gameplay , as i said 85 C is normal for a thin laptop like this but i'm afraid that in time those temps will affect the laptops intern parts .
Overall the laptop is worth the money and great service from PC Specialist, i would definitely recommend them for good/best price per performance laptops. I will add images later after i get the new better and bigger cooling pad.
If there are any questions about any aspect of the laptop that you might be interested i will gladly respond to pm.
