Diagnosing Hard Drive Issues
LFFPicard
Good Morning All,
Well for the second time in a month I come home and my PC has hardware issues :( It's had a good run since I ordered in 2011 now (Spec in sig)
My first issue was the Coolit AIO waterblock stopped working so I ordered a replacement H55 after a quick phone call to PCs and sorted that.
Last night I came home and the machine would freeze up every minute, the cursor would continue to work but everything else would stop responding. After about 30seconds it would all spring into life again for another minute. I painstakingly tried to check obvious, checked SMART status on all drives showing no issues. I finally went into event viewer and it has littered with "Event ID 129 – storachi – Reset to device, DeviceRaidPort0, was issued." and another error relating to disk0 (Forget what it was now)
After checking Disk Management disk0 was definatly my newish SanDisk SSD that the OS was installed on.
So....
After about an hour I managed to get Windows media creation tool to put a new copy on W10 on a USB stick. Restarted the machine, dumped both SSD drives and created new partitions for my old Intel SSD. I proceeded to install windows on this.
Windows10 is now back up and running running the basics, I have left the SanDisk unallocated while I try and do some tests. I managed to get Short and Extended Smart run on the SanDisk with SanDisk SSD Dashboard Management and they passed.
I am currently running a full destructive write+read surface scan on my original WD Black mechanical using HDSentinal. This estimates another 2hours to finish which would mean 8-9hours total running. No issues so far.
My question is, is there any other testing I can do on the SSD's I am sure the SanDisk is the issue but unsure best way to test it other than smart which I have done and it passes. But since switching back to the old SSD I have had no issues at all.
LFFPicard
Often, manufacturers will have testing apps in the downloads section for the drive. May be worth looking.
Yeah that's what the SanDisk SSD Dashboard was, it comes up clean.
HDSentinal finished the surface scan on the WD and that's clean, so I have now formatted it and it is installing some steam games.
I might Allocate the SanDisk again and put GTAV or something on it and try and give it a run see if the issue re-appears, I managed to finalled get an extended test done in HDSentinal as well as SanDisk dashboard and all clean.
At the moment the system is as follows.
OS Fresh install back on Intel SSD
WD Drive with Steam and a few games
SanDisk I will allocate and put a couple game son to test.
I guess it may have been a glitch randomly crop up and a fresh install has fixed it, I will just have to use the drives again to test them I think as all smarts come up clean.
Sorry, didn't read your post properly, missed that bit.
Smart has never really flagged issues for me, don't know if I'm just unlucky or what but it always seems to pass no matter what the issue is.
I'm out of my depth here, better let someone else take the mantle. It sounds to me like you've done some pretty good testing.
LFFPicard
Yeah I saw some of them ubuysa, some of the recommendations where to change power management to high performance. Someone even said it was down to a faulty SATA cable.
It's been running fine since Windows 10 install last year, just suddenly came home to it.
System seems fine at the moment so when I get home I will allocate the SanDisk and give it a trial.
