Do I Need a Bluetooth Dongle?
Pumpa Cat
Hi
I know this is probably a stupid question, but should I have received a Bluetooth dongle with my PC build?
I ask as I am trying to pair a wireless XBox controller to my PC. I have turned on Bluetooth on my PC and pressed the pair button with the controller, but nothing is found.
Having looked through some other Bluetooth related threads here I can see that others have had a similar problem whilst trying to pair. Often there is mention of a Bluetooth dongle.
Should I have received one from PCS, or is it something I need to purchase myself? Do I even need one or is it built into the Motherboard?
Thank you.
Processor (CPU) Intel® Core™ i9 16-Core Processor i9-12900KS (3.4GHz) 30MB Cache
Motherboard ASUS® ROG MAXIMUS Z790 HERO (DDR5, LGA1700, USB 3.2, PCIe 5.0)
ARGB Ready Memory (RAM) 32GB Corsair VENGEANCE DDR5 5200MHz (2 x 16GB)
Graphics Card 24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP Graphics
1st M.2 SSD Drive 2TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
2nd M.2 SSD Drive 1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Power Supply CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET
Power Cable 1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core)
Processor Cooling CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
LED Lighting 2 x 50cm Green LED Strip
Network Card ONBOARD LAN PORT Wireless Network Card NOT REQUIRED
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Windows 11 Home 64 Bit - inc. Single Licence [KUK-00003]
Can you post up your whole build from your order page? Be careful not to include the Windows key if it's in there.
It doesn't look like you selected wireless. Does the ROG Z790 have wireless on it? Usually it's mentioned in the product description.
Pumpa Cat
That is the whole build in my original post. I just didn't include things like case/software.
Looking at the configure gaming PCs page on the PCS website, it would appear there are no options for Bluetooth, which is probably why I assumed it was built into the Motherboard, or a dongle would be included. My bad I guess. I'll just have a look on Amazon and see what Bluetooth USB dongles they have.
You're missing what's being said, it already has Bluetooth on the board.
