Do PCS come overclocked?
Will my PC be arriving overlocked?
Only if you ordered an overclocked build.
But if you ordered a Ryzen build, overclocking will actually reduce performance for most uses because the way the cores are designed, it overclocks to the max of the weakest core which will be substantially less than the auto overclock it achieves normally.
Ganggang
Thank you!
not unless you've ordered an overclock, if you post your specs we can advise better
Thank you for the reply, I don't think I ordered an overclock build, I will post my specs when I get home. Thanks again,
