Do these sound ok?
Serendipity86
Hiya,
I have ordered a desktop and a laptop.
Both will mostly be used for things like world of warcraft, elder scrolls online and minecraft and I just wanted to check that they sound ok? Thanks
Desktop:
Case InWIN G7 BRUSHED EFFECT DARK GREY CASE
Processor (CPU): Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
Motherboard: Gigabyte Z97X Gaming 3: ATX, LG1150, USB 3.0, SATA 6GBs, XFIRE/SLI
Memory (RAM): 8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
Graphics Card: 2GB NVIDIA GEFORCE GTX 750 Ti - DVI, mHDMI, VGA - 3D Vision Ready
1st Hard Disk: 120GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 410MB/sW)
2nd Hard Disk: 1TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE)
1st DVD/BLU-RAY Drive: 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply: CORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Processor Cooling : Corsair H55 Hydro Series High Performance CPU Cooler
Extra Case Fans: 2 x 12CM Black Case Fan (configured to extract from rear/roof)
Operating System: Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Monitor: IIYAMA E2273HDS 22" LED WIDESCREEN, 2 HDMI/DVI-D 1920x1080
DVI-D & HDMI Monitor Cables : 1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE
Laptop:
Chassis & Display: Vortex Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Processor (CPU): Intel® Core™i7 Quad Core Mobile Processor i7-4710MQ (2.50GHz) 6MB
Memory (RAM): 8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
Graphics Card: NVIDIA® GeForce® GTX 860M - 4.0GB DDR5, 1152 CUDA Cores - DirectX® 11
Memory - Hard Disk: 250GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Thermal Paste: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Bluetooth & Wireless: GIGABIT LAN & WIRELESS INTEL® N-135 802.11N (150Mbps) + BLUETOOTH
External Hard Drive: WD 1TB Passport Ultra USB 3.0 External HDD - WDBZFP0010BBK
First one I would downgrade to the i5-4670 (non-k), downgrade the cpu cooler to the triple copper heatpipe, downgrade the motherboard to the hd3 gigabyte (no loss in performance). Since you have an SSD as your primary drive you won't get any benefits from a hybrid drive you may want to consider a caviar black as the secondary drive instead and I wouldn't bother with additional fans, if you want better cooling you are better off choosing a slightly more expensive case. I would also suggest going for at least the gtx 760 or higher if you are planning to play more demanding games in the future.
2nd one, if you are going with the gtx 860m it probably would be cheaper to get the Optimus chassis with the same gpu. I would also upgrade the thermal paste and get anything but the n135 wireless card, I had many problems with the same wireless card and there are other threads indicating similar problems
Serendipity86
Why would you downgrade so many things?
I considered getting the optimus as it was a little cheaper, but I liked the look of th vortex more, and it's keyboard and stuff.
Do you think the thermal paste is necessary? I have a friend who is good with computers and I asked him before I ordered if I should get the arctic paste, and he said it wasn't really needed and that the standard would be fine :S
Thanks for the tip on the wireless card, is there one you would suggest?
The downgrades are to do with getting a much better gaming PC for the same budhet. No need to have an unlocked cpu for Overclocking since it is not needed for gaming, you have a motherboard that supports SLI but considering your PSU I assume you are not planning to add a 2nd gpu and if you are not overclocking your cpu the triple copper is more than enough.
Serendipity86
Ok, and is that thermal paste really necessary for the laptop? I've looked at the wirless cards, the next one up is the N-7260, do you know of any problems with this one?
Serendipity86
I'm going to lower it to the i7-4790 (not K), will the copper pipe cooling be enough for this i7 processor?
And I have upped the graphics to the 760 4GB... and downed it to 1 fan instead of 2.
Gtx 760 is better, you can check benchmarks online. I would also upgrade the thermal paste, a laptop gets hot and any help with temps would help.
Serendipity86
Ok, final idea:
on the desktop:
change it to 1 extra fan, the copper heat pipe cpu cooler thing, and then change the processor to i5-4690k... if I do that I can get the 4GB 970...
Is it worth me dropping to the i5 and getting that graphics card?
Ok, final idea:
on the desktop:
Yes, the 970 will be a big noticeable difference, whereas the difference between i5 and i7 will not be so noticeable at all.
Also, is the gigabyte z97-HD3 motherboard good? Since I was originally getting the z97x gaming
You'll get the same performance, there'll be no difference. Personally though, I'd go for the gaming version as it has better audio and SLI capability, but only IF i could afford it. The most important components at the moment are the processor and the GPU, you want to get the best you possibly can. Mainly the more expensive boards are for overclocking potential which you won't be doing and isn't necessary for gaming anyway.
Serendipity86
[/QUOTE] You'll get the same performance, there'll be no difference. Personally though, I'd go for the gaming version as it has better audio and SLI capability, but only IF i could afford it. The most important components at the moment are the processor and the GPU, you want to get the best you possibly can. Mainly the more expensive boards are for overclocking potential which you won't be doing and isn't necessary for gaming anyway.[/QUOTE]
I can't afford the z97x if i get the gtx 970
I can't afford the z97x if i get the gtx 970[/QUOTE]
In that case, I'd chose the 970 over the z97x and go with the z97-hd3. You'll get more gaming power with the GPU, the board won't really enhance gaming potential.
