Does PCSpecialist stock CL30 or CL32 RAM?
stratos
I'm building a PC here, and it doesn't say the CL of the RAM being used. This is the RAM I'm going for:
64GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 32GB)
Would really appreciate if people could advise! Considering just buying my own RAM separately if they don't stock low-latency RAM.
Best thing to do is give them a call and ask them, none of us work for them so can't tell you.
If they don't then just add the smallest and cheapest option possible and source your own
You'd have to check with PCS themselves (or with someone who has that exact RAM in their build and can check with (CPU-Z).
For reference my Corsair Dominator Titanium 6400MHz is 32-40-40-84
But, you might want to watch this before chasing the lowest primary timings...
