Dust control
Sammcl
Anyone got some good tips for dust control, inside of my pc is no where near bad enough to require a compressed air can yet but the outside case can contract a fair amount of dust..?
tom_gr7
Life Serving
what case have you got?
extra dust filters can limit the dust, but really dust is going to get in there anyway.
so
- Compressed air as chriso said.
- dust filters on the fan intakes. Silverstonetek do some really good low cost ones, so look out for them.
DeadEyeDuk
Superhero Level Poster
I believe the best and only real solution is to put your PC in a vacuum room, and then wear a protective pressurised suit when ever you want to use it.
That said, dust is a cheeky little monkey and will probably find a way in regardless :D
Sammcl
Hey guys sorry for late reply, I've got the InWin MaNA 136 Black Gaming Case. Don't really want to get dust filters for fans I'll be honest as i've heard they can raise temperatures. Guess It's the good old air can, cheers for replies!
