Zer0access
Could anyone check this spec? I'm trying to decide between this and the MSI GE75. Both would be for some hardcore gaming (Far Cry 5, Witcher, Battlefield, Cod and League of Legends) so higher the FPS the happier I am. Mostly though I am concerned about heating. My last laptop ran way to hot so I am looking for a laptop that won't run that hot. Not bothered about fan noise. Last important thing for me is a good keyboard. How are people finding the Recoil 3 keyboard?
Should I get an SSD for storage or will it have no impact on storage if I get a regular HD? (it won't be used for gaming at all)
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Get Total War: Three Kingdoms & More w/ select Intel CPUs!
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
Get Control & Wolfenstein: Young Blood w/ select GeForce RTX GPUs!
1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (7,200rpm)
Choose from 6 Incredible Ubisoft Titles FREE with select SAMSUNG NVMe SSDs!
Integrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor
1 x 230W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
1 x 1 Metre European Power Cable (Kettle Lead)
Bluetooth & Wireless
GIGABIT LAN & KILLER™ WIRELESS-AC 1550 M.2 GAMING 802.11AC + BLUETOOTH 5.0
PER-KEY RGB BACKLIT USA QUIET MECHANICAL KEYBOARD
Thank you!
AC Adaptor
1 x 230W AC Adaptor
Thank you!
