FAN making strange noise
AndrePaulo
Hello!
I have a Defiance Series: 15.6 (September 2020) and recently I've been hearing some weird noise from the fans.
Here's a video:
This sound starts every once in a while, and after some time it randomly stops. It doesn't matter the fan speed (in the video it started on Maximum, and then changed it back to automatic).
I've had this for some time now, one day I opened it to clean the fans, and it stopped for a couple hours, and returned right after.
There doesn't seem to be caused by a wire staying on the fan.
Is there something I can do to fix this, or should I contact support directly?
Any help would be appreciated.
AndrePaulo
If by "when you last serviced it" means last time I cleaned it, was no longer than a week ago. And these noises started before that, and are still present today (for example right now)
Full Specs:
Defiance Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
512GB INTEL® 660p M.2 NVMe PCIe SSD (up to 1500MB/sR | 1000MB/sW)
AC Adaptor
1 x 180W AC Adaptor
1 x 1.5 Metre Cloverleaf European Power Cable
Defiance Series Integrated 3 Cell Lithium Ion Battery (73WH)
1 x THUNDERBOLT 3 PORT + 3 x USB 3.2 PORTS
15" DEFIANCE SERIES PORTUGUESE KEYBOARD
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
INTEGRATED 1MP HD WEBCAM
5 DAY DELIVERY TO PORTUGAL
Welcome Book
Full Specs:
AC Adaptor
1 x 180W AC Adaptor
Microsoft® Edge
Welcome Book
Did you repaste the gpu and cpu? If not when wad the last time you did that?
AndrePaulo
It does sounds like either a beading has gone, or it's slightly contacting something like a cable
There are no cables touching the fans, otherwise it would probably always sound like that.
If its a bearing, is there anything I could do?
