Yeah I'll give it a go is it on the front of the mb?It's likely to be a loose connection. Would you be comfortable unplugging it and plugging it back in?
Should be! I'd have a google of where the fan headders are on your mobo to make sure you're unplugging the right thing! (baring in mind there will be multiple 😂Yeah I'll give it a go is it on the front of the mb?
No that didn't work 😞
Thanks for trying anyway I appreciate it 😊Someone with more technical knowhow might be reqiured then, I'm never very good when it comes to troubleshooting
Fantastic, glad to hear!Got it ☺️ the power wasn't connected, I'm not sure if it came out in transit or they hadn't been connected in the first place but either way I've put the power back in and now it's all working.
