I work from home, Running a 2014 - PCS 4790k /Z97A/ 16gb DDR3 /SSD + RTX 2060 (32in monitor at 4k + 1 24in) - all ok still...!
the below is for a second PC for a new office and will sometimes work from home or in the office...software mainly CAD/ Photoshop/Indesign/Lightroom/Acrobat/Bluebeam/Sketch up/TwinMotion/Office/Streaming...
so trying to get the best bang for the buck as efficient/cost-effective/ future proof as possible, also trying to get as much speed overall keeping the budget to the minimum...
Not sure about the case...
Ram not sure the frequency gives any benefit? - 16gb is ok for me, can add another 16gb when budget allows...
Went for this FIRECUDA as the main OS drive as will be fastests? - I use one drive (about 750mb) to sync between my systems...and think can only be on the C drive...?
Cooling - have seen a few youtube
saying the standard AMD cooler (wraith prism?) is fine and the additional cost for coolers isn't worth the money...?
As I understand it if you already have a Windows license you don't need additional?
Haven't decided on the graphics card, I have a standard RTX 2060 (which I found new on eBay for a steal) and seems to be fine for my needs...would probably go just above that if anything.
Thanks!
Steven
PCSPECIALIST.CO.UK SPECIFICATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
CORSAIR CARBIDE SERIES™ 200R COMPACT GAMING CASE
STANDARD AMD CPU COOLER
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 21 to 23 working days
Price: £1,220.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/H40dxYdHHj/
Thanks!
Steven
