hitman2195
Any help/thoughts would be great.
Im making this build with high end gaming in mind and I will be using the Samsung G7 32 inch 1440p 240htz monitor.
1. Would the Fractal Design Define case work just as well as the one I have chosen?
2. I have added the Rog Strix Geforce 3080 .but will i see enough performance boost out of it or should I just get the normal 3080.
3. I have chosen 32gb of 3600 ram would 16gb suffice?
4. Is it worth waiting for the 6800x big navi gpu or should I stick with the 3080?
5. Are there any other things you can see from the build below that you would change/remove/add?
CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP (Xmas delivery not guaranteed)
Corsair H115i PRO Cooler w/ PCS Ultra Quiet Fans
Firefox™
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Price: £2,756.00 including VAT and Delivery
Firefox™
