final spec,hopefully
vanthus
Member Resting in Peace
Will this spec suffice to play crysis2 on medium or if not low settings?not interested really in overclocking so not sure best processor cooling to get,but dont want one thats going to be noisy.
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB ATI RADEON™ HD 5850 PCI EXPRESS - DirectX® 11
2nd Graphics Card
NONE
3rd Hard Disk
RAID
NONE
10x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£89)
2nd DVD/BLU-RAY Drive
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
CORSAIR 650W PSU (TX650) 80+ ULTRA QUIET (£76)
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Sound Blaster® X-Fi™ Titanium PCI Express (£66)
ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
TV Card
HAUPPAUGE HI-DEF SATELITTE DVB-S2 TV RECIEVER (WinTV-NOVA-HD-S2)
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£108)
PCS
Administrator
Staff member
It will suffice to play on medium/high settings! :D
My only advice is - do you really need two optical drives? You can read/write DVD's with your Blu-ray writer drive, and therefore unless you plan to copy directly from disc to disc on a regular occasion you can remove the DVD Writer drive.
vanthus
Glad you asked that,im hedging my bets here,my present pc which ill still keep on using as ive hundreds of apps & games(mostly for the kids) onit,anyway optical drive is on the road out,so i thought(probably stupidly)i might just replace it with the new one.thing is its an ide connection,but if the new one is sata ill need a converter,hence the stupid bit.but still it would be handy for me for disc to disc as you say,& its only 20 quid.
PCS
Administrator
Staff member
Just in case you weren't aware - you can still copy from disc to disc using one drive, but it's a little slower as it first images it to your hard drive, then burns it to the new DVD/CD.
vanthus
yes,i have a few apps that do that,having the 2 would save you watching when you have to change the disc,but maybe a feeble excuse for having 2.but thanks for your advice.hope someone will still advise me about processor cooler.
sorry,replied with wrong quote.
PCS
Administrator
Staff member
Hope someone will still advise me about processor cooler.
The Titan Fenrir is a great cooler, and the best air-based cooler we offer. It will keep the 965 processor very cool and as a result keep your system running quiet.
The Eco (next step up) will be marginally quieter than the Fenrir, and keep the CPU even cooler. But it's an optional purchase, not a requirement. On the flipside the Triple Copper Heatpipe cooler will also keep your system very cool, although it's not as efficient as the Titan Fenrir. It will however save you £20.
vanthus
thanks for that PCS.thought i was ready to go but sleinous keeps putting doubts in my head.will my 1st hard drive be ok,i plan to have it partitioned for os.
