Fingerprint scanner's drivers win10
xmuriellx
Not long time ago became the owner of a laptop PCX0DX Defiance 17" and today my fingerprint scanner isn't worked.
In devices manager in windows 10 it shows like unknown device without possibilities to refresh drivers.
DevId :
USB\VID_06CB&PID_00A8&REV_0154
Where I can find drivers for this one please ?
DevId :
Did you buy from PCS? Could you post your full specs please from the order page?
xmuriellx
Yeah, Its was from PCS.
Code:
Chassis & Display    Defiance Series : Écran large LED mat 17,3 pouces 144 Hz 72 % NTSC Full HD (1920 x 1080)
Processor (CPU)    Processeur Huit Core Intel® Core® i7 10875H (2,6 GHz, 5.1 GHz Turbo)
Memory (RAM)    32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
Graphics Card    NVIDIA® GeForce® RTX 2070 Max-Q - 8 Go de RAM vidéo GDDR6 - DirectX® 12.1
1st M.2 SSD Drive    1 To Intel® H10 NVMe SSD + 32 Go Intel® Optane™ (jusqu'à 2400 Mo/sR | 1800 Mo/sW)
Memory Card Reader    Lecteur de carte mémoire Micro-SD intégré
AC Adaptor    1 ADAPTATEUR C.A. 180 W
Power Cable    1 câble d'alimentation européen Cloverleaf, 1 m
Battery    Batterie lithium-ion 3 cellules Defiance Series (73 WH)
Thermal Paste    PÂTE THERMIQUE STANDARD POUR UN REFROIDISSEMENT EFFICACE
Change to: ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Sound Card    High Definition Audio 2 canaux + prise MIC/casque
Bluetooth & Wireless    GIGABIT LAN ET WI-FI INTEL® Wi-Fi 6 AX200 (2,4 Gbps) + BT 5.0
Change to: GIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options    1 THUNDERBOLT 3 PORT + 3 PORTS USB 3.2
Keyboard Language    DEFIANCE SERIES USA KEYBOARD
Operating System    Windows 10 Famille 64 bits - Licence mono-utilisateur incluse [KUK-00001]
Change to: NO OPERATING SYSTEM REQUIRED
Operating System Language    US International/USA - US English Language
Windows Recovery Media    Image de restauration multi-langue Windows 10 - Téléchargements illimités depuis votre compte en ligne.
Change to: NO RECOVERY MEDIA REQUIRED
Office Software    Essai GRATUIT de Microsoft® Office® 365 (système d’exploitation requis) pendant 30 jours
Anti-Virus    BullGuard™ Internet Security - Licence d'utilisation 90 jours gratuits incl. mode Gamer
Change to: NO ANTI-VIRUS SOFTWARE
Browser    Microsoft® Edge (Windows 10 uniquement)
Notebook Mouse    SOURIS TOUCHPAD 2 BOUTONS INTÉGRÉE
Webcam    WEBCAM INTÉGRÉE 1 MP HD
Warranty    Garantie standard de 3 ans (1 mois collection et retour, 1 ans pièces, 3 ans main d'œuvre)
Delivery    LIVRAISON EN 2 - 6 JOURS POUR L'EUROPE (SELON LES PAYS)
Build Time    EXPÉDITION EXPRESS 5 JOURS OUVRABLES
Build Time    Assemblage standard - Environ 3 à 5 jours ouvrables
Detailed Specification
Dimensions & Weight
Dimensions (w x d x h)    395.9mm x 264.95mm x 19.9mm
Weight    2.3 Kg (inc. battery)
Colour    Grey/Black
Chipset
Processor Support    10th Generation Intel Processor Support
Memory
Memory Type    Supports DDR4 2666MHz
Number of Modules    2 x 1GB/2GB/4GB/8GB/16GB Modules
Maximum Supported Memory    64GB
Hard Drive Capacity
M.2 Port    2 x M.2 2280 SSD Ports, 1 x WLAN M.2 2230
Display & Graphics
Graphics    Choice of graphics cards - refer to configurator.
Screen Size    17.3 inch Widescreen
Native/Maximum Resolution    1920 x 1080
Refresh Rate    144 Hz
NTSC    72%
Audio
Chipset    High Definition Audio + SOUND BLASTER™ Atlas
Channels    2 channel HD Audio
Connections    2 x 2-in-1 Audio jack
Speakers    Built in two speakers
Integrated Microphone    Yes, Array Microphone
Communications
Wireless Support    Wireless LAN 802.11ax/ac/b/g/n (M.2 Interface)
Bluetooth Support    Bluetooth V5.0 module support
Webcam    1.0 MP Webcam
Keys    Multi colour backlit isolated keyboard
Language Support    Multi-Language support
Pointing Device | Touchpad Mouse    Built in touch pad with multi-gesture and scrolling function
Backlit Keyboard    Yes
Memory Card Reader    1 x Micro SD Card Slot
Ports
LAN    1 x RJ-45 jack
USB    1 x Thunderbolt™ 3 Port, 3 x USB 3.2 Gen 1 Ports
Display    1 x HDMI, 1 x Mini DP, 1 x Thunderbolt™ 3
Microphone-IN    1 x 2-in-1 Audio jack (Headphone / Microphone)
Headphone-OUT    1 x 2-in-1 Audio jack (Microphone / S/PDIF optical)
DC-in    1
Battery & Power Lead
Battery Capacity    Lithium-Ion, 73WH
Typical Battery Life    Up to 5 Hours (in UMA mode)
Battery Type    Integrated
Power Lead & AC Adpater    1 x Power Lead included with AC Adapter
Security
Fingerprint Scanner    Yes
Kensington Lock    Yes
Temperature
Thermal Performance    Due to the high performance components built into this ultra slim laptop, the exterior chassis temperature can reach approximately 45°C when running under full load. This laptop model has been fully tested and meets all thermal requirements, so performance & stability are not affected in any way. If you have any further questions about this laptop, please contact our sales team.
Code:
Dimensions & Weight
Colour    Grey/Black
Chipset
Memory
Hard Drive Capacity
Display & Graphics
Refresh Rate    144 Hz
NTSC    72%
Audio
Communications
Ports
LAN    1 x RJ-45 jack
DC-in    1
Security
Kensington Lock    Yes
Temperature
So if you login to your main PCS account, all your drivers are in the download section
xmuriellx
OK. Now I find it.
So tell me please, witch one is for fingerprint's scanner ?
xmuriellx
resume.
No one of those 12 *.zip drivers doesn't work. And in dev-list in windows this fingerprints scanner still like %unknown device%
B4zookaw
Click View Optional updates under check now button. There is probably drivers to install or update
