JohnPatterson547
Hi all,
First post here, so go easy on me
I'm looking to replace my main desktop PC which is very long in the tooth, and although I've done a little research I'm quite out of the loop on current PC hardware. So any advice and recommendations would be welcome and appreciated.
My main anticipated uses of the PC are:
- photo management: lots of scanning through a reasonable sized collection and reading/processing of metadata
- running VMs: I intend to run Linux as the OS, but I want to be able to run Windows 10+ and Linux in (probably VirtualBox) VMs at times
- some development work: primarily Java in IntelliJ, but occasionally C, potentially some Go or Rust
- general use (web, playing music, etc)
I'm not intending to use it for gaming, though I don't want to totally rule it out! I'd probably look to add a reasonable graphics card later if that ever became something I wanted to do. I'm just going to use it with a fairly standard 1080p monitor for now, but I'm thinking about upgrading to something higher res later.
So I think I want to prioritise lots of local fast storage, and memory, over CPU grunt or graphics.
I have a rough budget of 1000 - 1500, though that's a little flexible.
Here's what I picked out as a first draft:
FRACTAL FOCUS G BLACK GAMING CASE (Window)
Intel® Core™ i5 Six Core Processor i5-11400 (2.6GHz) 12MB Cache
ASUS® PRIME Z590-P (LGA1200, USB 3.2, PCIe 4.0) - ARGB Ready
16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & SOFTWARE
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
STANDARD CPU COOLER
Standard Build - Approximately 16 to 19 working days
Welcome Book
Price: £1,302.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z590-pc/GvGxp8p7m4/
I'm especially unsure about the PSU, cooling and paste options.
I'm guessing the first bit of feedback will be to avoid Intel and go for AMD - I'm not opposed to that, but I know (even) less about that, and it seemed to jump the price up!
What do you think? As I say, any advice welcome
STANDARD CPU COOLER
Welcome Book
