Hi all, I've put together a spec for a laptop (which I would like to keep at 17.3" screen size) that can easily play the Sims 4 and which has a French keyboard/OS language. Could you please give your feedback on the spec, and recommend anything you would improve/remove, as I feel like it might be overly-equipped for the task at hand. Cheers!
www.pcspecialist.co.uk
Elimina Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 12 Core Processor 12500H (4.5GHz Turbo)
16GB Corsair 3200MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® GTX 1650 - 4.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 120W AC Adaptor
Elimina Series Integrated 54WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 + BT 5.0
2 x USB 3.2 PORTS (Type C) + 1 x USB 3.2 PORT + 1 x USB 2.0 PORT
ELIMINA 17" SERIES MULTI COLOUR BACKLIT FRENCH KEYBOARD
France/République Française - French Language
Microsoft® Office Home & Student 2021 (1 Digital License)
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NP70PNH (4GB GTX-1650, i5-12500H, AX201, 144Hz N7, Blank KB)
Standard Build - Approximately 2 to 4 working days
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
AC Adaptor
1 x 120W AC Adaptor
Chassis
