Stevewtw
Hi
One of my USB ports in the front of my PC is not working (the other one is fine). Whenever I plug any device into it, I get a message saying that the device has malfunctioned.
I have tried many different types of devices and they all fail. My Device Manager and Event Viewer has some errors in it (see below). Also see my full computer spec.
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Date: 27/12/2020 00:53:44
Event ID: 411
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: DESKTOP-KGSKUMM
Description:
Device USB\VID_0000&PID_0002\8&1b878445&0&2 had a problem starting.
Driver Name: usb.inf
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Service:
Lower Filters:
Upper Filters:
Problem: 0x2B
Problem Status: 0x0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9c205a39-1250-487d-abd7-e831c6290539}" />
<EventID>411</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2020-12-27T00:53:44.9639378Z" />
<EventRecordID>839</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8032" />
<Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
<Computer>DESKTOP-KGSKUMM</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DeviceInstanceId">USB\VID_0000&PID_0002\8&1b878445&0&2</Data>
<Data Name="DriverName">usb.inf</Data>
<Data Name="ClassGuid">{36fc9e60-c465-11cf-8056-444553540000}</Data>
<Data Name="ServiceName">
</Data>
<Data Name="LowerFilters">
</Data>
<Data Name="UpperFilters">
</Data>
<Data Name="Problem">0x2b</Data>
<Data Name="Status">0x0</Data>
</EventData>
</Event>
Event ID: 411
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Description:
Service:
Lower Filters:
Upper Filters:
Problem: 0x2B
Problem Status: 0x0
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</Data>
</Data>
</Data>
</EventData>
</Event>
Case | Send In Your Own Case (View Details) |
Case Model: | Lian Li pc-o11dw Case For PC White |
Case From: | |
Processor (CPU) | AMD Ryzen 5 3600X Six Core CPU (3.8GHz-4.4GHz/36MB CACHE/AM4)![]() |
Motherboard | ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready! |
Memory (RAM) | 32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB) |
Graphics Card | 10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP![]() |
1st Storage Drive | NOT REQUIRED |
1st M.2 SSD Drive | 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) |
2nd M.2 SSD Drive | 1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)![]() |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET![]() |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Braided Power Supply Cables | NONE![]() |
Processor Cooling | STANDARD AMD CPU COOLER![]() |
Thermal Paste | ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND |
Extra Case Fans | 3x Corsair LL120 RGB LED Fan + Controller Kit |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
Wireless Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
