Gaming rig.
Lovejoy96
Hey guys, originally I was thinking about investing into a desktop PC, but it'll be a lot more logical to get a laptop for portability etc. I am looking into a laptop which will fall into the £900-1000 price range which will cover the following.
- 15 inch
- Optimus
- day to day browsing
- general work
- multiple applications at once (nothing intensive, YouTube etc)
- gaming *important, looking to play wildstar*
Here are the minimum specs for Wildstar;
CPU: Intel Pentium Core2 Duo 2.4 GHz, AMD Phenom X3 2.3 GHz, or better
CPU Speed: Info
RAM: 4 GB
OS: Windows XP
Video Card: NVIDIA GeForce 8800 GT, ATI Radeon HD 3850, or better
Sound Card: Yes
Free Disk Space: 30 GB
Recommended;
CPU: Intel Core i5 Quad Core 2.66GHz or better, AMD Phenom II X4 3GHz, or better
CPU Speed: Info
RAM: 8 GB
OS: Windows Vista (64-bit)
Video Card: NVIDIA GeForce GTX 460 or ATI Radeon HD 5830
Sound Card: Yes
Thanks all!
One thread is enough :) Here is my suggestion:
COOLERMASTER CM690 III ADVANCED CASE
Intel® Core™i5 Quad Core Processor i5-4690 (3.5GHz) 6MB Cache
Gigabyte Z97X Gaming 3: ATX, LG1150, USB 3.0, SATA 6GBs, XFIRE/SLI
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
Free Item
FREE WATCH DOGS with GTX 660 & 7 Series GPUs!
1st Hard Disk
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Price: £921.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-pc/YdEvVM0t0Z/
Lovejoy96
Thanks for the response, apologies I didn't know what section to post in. If I had an extra 80-90 pounds to spend what do you recommend in terms of an upgrade?
Lovejoy96
Gaming laptop.
Hey folks, want to run Wildstar on pretty high settings with no FPS issues; Here are Wildstars min req.
RAM: 4GB
Graphics Card: NVIDIA GeForce 8800 GT, ATI Radeon HD 3850, or better
Operating Systems: Windows XP SP2 (64-bit) or later. 32-bit systems are not supported during beta
I have around 80-90 pounds left too spend, any upgrades you guys recommend?
Optimus Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4710MQ (2.50GHz) 6MB
8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
NVIDIA® GeForce® GTX 860M - 2.0GB DDR5, 640 CUDA Cores - DirectX® 11
Memory - Hard Disk
1TB SEAGATE HYBRID GEN3 SSHD Drive, SATA 6 Gb/s, 64MB CACHE (5400 rpm)
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
NORTON ANTI-VIRUS 2014 - 1 Year Licence for 1 PC (£10) *SPECIAL*
BACKLIT OPTIMUS UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
Insurance
Price: £903.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/optimusV-15/RcPMqXKVtO/
another thread? Why don't you stick to the original one? It prevents others from repeating the advice you got and you can get better feedback as well.
steaky360
Only reason I didn't merge them is that the OP was looking for a desktop last time and this is a laptop... However, I will merge them as the advice given could be the same for both.
My bad :( Shouldn't post before 7am
Stephen M
As A314159 said about the previous, try a Hyper X SSD. The hybrid drives are not up to much, you have no control on what goes where on them and you need the OS and main progs on the SSD part. A Kingston Hyper X 120 GB along with a Scorpio Black (750GB) second drive will be about 50 quid more but be a better option.
Lovejoy96
Laptop advice
- 15 inch
- Optimus
- general work
CPU Speed: Info
RAM: 4 GB
OS: Windows XP
Sound Card: Yes
Recommended;
CPU Speed: Info
RAM: 8 GB
Sound Card: Yes
Thanks all!
Rakk
The Awesome
Since your last post in the other (merged) thread was about laptops as well, I've merged your threads together and moved them to this section of the forums, it's better to keep to the same thread where possible because it means people are less likely to ask/answer the same things multiple times.
Lovejoy96
Sorry this is confusing me haha, I thought the thread didn't post last night but it got merged into this one. Apologies, any spec recommendations greatly appreciated.
A314159
Super Star
Get the cheapest quad core processor around, the cheapest 8gb RAM you can find and then find a chassis with a GPU that uses the rest of most of your budget. Then get a decent HDD, an SSD if you want, and customise with weird extra like thermal paste.
Jamie0202
Vortex Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
NVIDIA® GeForce® GTX 870M - 6.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
GIGABIT LAN & WIRELESS 802.11N CARD + BLUETOOTH 3.0
Firewire
1 X 1394a FIREWIRE PORT
INTEGRATED UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
Insurance
Price: £1,016.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/vortexIV-LE/PYZRkbNQoG/
You'll be glad you went with a faster graphics card if you go for this rig. An SSD can be added at a later date if required. I also chose the Vortex over the slightly cheaper Skyfire due to having a 6GB 870m over the 3GB 870m. Until last week I thought that 3GB was a huge amount of vram but then Ubisoft released Watchdogs. If that's anything to go by then future open world cross-platform games could perform better with extra vram due to the consoles having 8GB of unified ram.
