ClaytonJoness
i recently bought a new desktop, and i didnt get a graphics card with it because i didnt have enough money at the time. so would any one recommend me a graphics card to buy seperately in the future, these are my specs.
AMD PHENOM II X6 1075T (3.00GHz/9MB CACHE/AM3/) - BLACK EDITION
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
2nd Graphics Card
NONE
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
Phoenix
Well it depends on what budget you have, I recommend the HD6870 though if you can afford one (£184.10 from scan.co.uk).
Gorman
Any card you do decide on may be cheaper through us, worth giving the call centre a shout on 0844 499 4000 for a quote.
Phoenix
With such a weak power supply the best graphics card you can get is the HD5570, anything higher will really push you power supply.
