This is a copy n paste job of the email I sent PC specialist. To be honest, they haven't been very helpful. The first time I rang them, they told me to just send in all the details in an email including the card serial number. I did that over ten days ago and had no response. I rang them again today and they would not help me at all besides tell me that they never got my email and that the card is out of warranty.
I recently rang in to your customer support and they advised me to send in all the details via email including the gfx serial number. Card serial number is S/N T8100123939
When using the computer, mainly in games the temp of the card is going up to and above 100c. I know gtx 480 is supposed to be a hot card but when I first got the machine it was only doing 90 sometimes 93. Recently it is going above 100c, usually going to 107c.
Seems to run but my computer is just turning itself off all the time now when under load and the fans etc I can still hear running.
I believe it is the card that is overheating. Sometimes when I turn the computer back on after it has turned itself off, the first screen (a black one) is telling me over clocked failed reset settings in bios. This only happens sometimes though, mostly I get the computer did not shut down properly.
I am actually using 12gb of RAM, I bought another 6gb of the same type I ordered below if this has anything to do with it at all.
The technical team I believe told me it could be just the card itself and I should send in the serial number to see if is still in warranty.
Card seems to idle at 65c using auto fan speed.
obviously the days are getting hotter but I keep the window open so the room is usually cool.
Is there anything I can do, maybe contact the actual manufacturer myself? I have no idea which company made my gfx 480.
Would I be better off buying some after market cooling or whatever it is? I'm not sure i could or would feel comfortable taking apart the card to put this on. Likewise it has been years since I've put together a pc, I also don't feel 100% putting a new one is, the gtx 480 is big and does take alot of room though. Also i'm not sure I want to simply spend £200+ on a new card that probably would be inferior and there is a small chance it might not even be the card ( I doubt that though).
Sorry if it is abit of a rant. I Spent alot of money on this pc and it still runs everything good. it is not like the card has gone crap, just that I don't want to spend alot of money on a new card for similar or less performance, money is tight at the moment.
All drivers are up to date, and I monitor the temps with different programmes. I have cleaned the entire computer inside with an air blaster. Not removed the card from the socket but have still cleaned it.
Card/computer was bought brand new in july/august 2010.
Case PCS MAELSTROM T900 BLACK GAMING CASE
Overclocked CPU OverClocked Intel® Core™i7 Quad Core Processor i7-930 (2.8GHz @ max 3.8GHz)
OC Settings Show/Hide
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 6GB KINGSTON HYPER-X TRI-DDR3 1600MHz, INTEL X.M.P (3 x 2GB KIT)
Graphics Card 1536MB NVIDIA GEFORCE GTX480 GDDR5 PCI EXPRESS - DirectX® 11
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 640GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
1st Hard Disk Partitions 640GB, GB
2nd Hard Disk 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
2nd Hard Disk Partitions 500GB, 500GB
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply CORSAIR 850W PSU (TX850) 80+ ULTRA QUIET (£100)
Processor Cooling TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Thermal Paste ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
RAID NONE
Firewire NONE
TV Card NONE
