policematrix
just google GTX 970 and you will see the problem Nvidia has lied/kept secret the truth behind the card, for instance the card can only use 3.5 VRAM the other 500mb is a slower version that when accessed can make frame times go through the roof even leading to crashes in many cases, for all the latest info try these links
https://forums.geforce.com/default/...tx-970-3-5gb-vram-issue/post/4438166/#4438166 Nvidia admins offering to help GTX970 owners get a refund from there retailers
https://www.change.org/p/nvidia-refund-for-gtx-970 pettition with 2.133 supporters
http://www.pcper.com/reviews/Graphi...cture-and-Limitations-GTX-970?page=1#comments here is the specs (remember this interviewer gets free cards etc from nvidia so hes like a timid dog but still gets some facts from nvidia)
GTX 970 (Original) GTX 970 (Corrected)
CUDA 1664 1664
Texture units 104 104
ROPs 64 56
Core Clock 1050MHz 1050MHz
Boost Clock 1178MHz 1178MHz
Memory Clock 7GHz GDDR5 7GHz GDDR5
Memory Bus Width 256-bit 256-bit
L2 Cache 2MB 1.75MB
So it was sold to you and me using false advertisements mine has stuttered since day one even when not using the bad VRAM and I RMAd it when i first got it complaining of stuttering, pc specialist did a benchmark and most likley left it running came back looked at FPS and said whats the problem ?
Well the problem is you may well get good FPS while recieving frametimes of over 200ms (average ms for online gaming is 20 -60 ms ) I took some pictures to show the problem more clearly
this shows frametimes in comparison to FPS as you can see FPS look good until you see those big frametime spikes
here is the VRAM test showing just how slow that portion is (mines starts to slow anything over 3G)
My question is this will PC Specalists refund my card / store credit / swap for similar or do none of the above? Nvidia are offering to help sort this out so they know they screwed up big time here, others are talking of a lawsuit all i want is a card that runs smooth and does what it says on the tin.
And what are the implacations of this even if your card works for you fine? well card has devalued (and so have Nvidia shares) so resale value has depleated over night, and what about SLi ? this was my idea of some futureproofing but there is no way I will by another one of these so thats out the window also =( And finally 4k gaming is off also as this is the most likley time your card will tap into that slow VRAM and crash or freeze
Now it is clear not everyone has the stutters all the time some only get it when using that extra 500mb vRAM but all cards have been misrepresented and all card suffer in this 500mb zone
Your views and experiences would be greatly apreciated.
P.S like I say my card has not worked correctly since day 1 and if it was working properly I would not want a refund
CUDA 1664 1664
ROPs 64 56
L2 Cache 2MB 1.75MB
