One thing to note is that I am waiting for the 7000X3D cpus to come out and I will definitely get one of those instead of the 'placeholder' I have below, I will be getting either the Ryzen 7 7800X3D or the Ryzen 9 7900X3D depending on gaming benchmarks and reviews, I'm open to any feedback, please let me know. One of my concerns is if the case is good enough or if it's gonna have any issues (bending) with the power adaptor on the 4090. Let me know
Budget is not an issue*
For monitor I will either go with the
LG 27GR95QE-B 1440p/240hz thats coming out soon or the ASUS PG27AQN 1440p/360hz
and will probably get a 4k one at some point in the future too
AMD Ryzen 9 7900X 12 Core CPU (4.7GHz-5.6GHz/76MB CACHE/AM5)
ASUS® TUF GAMING X670E-PLUS WIFI (DDR5, PCIe 5.0) - RGB Ready!
32GB Corsair DOMINATOR PLATINUM RGB DDR5 6000MHz (2 x 16GB)
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
4TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
3x Corsair LL120 RGB LED Fan + Controller Kit
Microsoft® Edge
https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/MwE5pCQeUN/
Microsoft® Edge
