Help to choose a monitor for RTX 3070
JustTom9
I'm just researching so much and not getting anywhere...
My budget can go up to around £600 if it's worth it.
I'm not really interested in ultra wide.
Main uses of my new build, which is coming Tuesday with a 5800x and a RTX 3070 are going to be gaming. Main is Warzone but I play a lot of other games like Tarkov etc.
Basically, do I go 1440 144hz? Do I go 1080 240hz? Oooor do I go over budget and go for a 1440 240hz?
Any advice appreciated. Thanks
Given the games you play and your budget, we should be able to get a 1440p 240Hz monitor in just about, might go slightly over, but gives you room to grow with a GPU upgrade.
There are basically 2 options:
HP Omen 27 which is usually the one people choose as has better reviews and is currently around £550 and flat:
Or the Samsung G7 32" which is around £580 and curved:
SlimCini
KC and the Sunshine BANNED
If you're a teacher you can get the hp omen from the hp store for £494 making it even more of a bargain.
