Help with Gaming build
t_dawg
Hi guys,
Been a long time viewer on this forum around latest specs and PC builds etc. I have finally gotten round to speccing up a new gaming PC for myself now that the 9800X3D is imminent. Main use case is for gaming, some FPS games including COD, Tarkov, Dark and Darker to name a few.
I dont have a gaming monitor yet, but looking to purchase a 1440p ultra-wide 165hz Alienware qd-oled monitor (AW3423DWF). So in that respect, I am looking for a 1440p build.
Budget for the build (without the monitor) is around £2800 so would appreciate your thoughts on this build please. Aesthetic is black with some RGB elements. I added extra case fans but wasn't sure if this would be necessary for cooling? Also the CPU is a placeholder for the 9800X3D.
Thanks in advance for your advice on the build (and the monitor if you like :)
AMD Ryzen 7 9700X Eight Core CPU (3.8GHz-5.5GHz/40MB CACHE/AM5)
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB)
16GB ZOTAC GEFORCE RTX 4070 Ti SUPER TRINITY BLACK EDITION - HDMI, 3 x DP
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
3 x Corsair ICUE LINK RX120 RGB PWM Fan + Controller Kit
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £2,570.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/RhqQ0cztkk/
Ekans2011
Any thoughts/advice?
It seems nice to me; I'd remove the extra fans because they're unnecessary, but if you value aesthetics, you may leave them (just be sure to configure them properly or you'll get the opposite effect in terms of cooling).
If NVIDIA technologies are not crucial, try an AMD GPU such as the 7900XT, which has better raster performance than the 4070ti SUPER at a cheaper price (about £100 less).
t_dawg
Thank you for this. I did think about the AMD GPU however I prefer NVidia for GPU so think I will stick to that. RE fans noted thanks.
If I were to change to a 4K 200+ hz monitor, what would you change in the build? Change to a 4080 super? I’m still torn between the 1440p or 4K setup.
Ekans2011
Personally, I believe that QHD/Ultrawide 1440p is the best resolution for gaming; but, if you want 4K, simply put in a 4080 SUPER/7900XTX and you should be OK.
At this stage I wouldn't be buying a 4k GPU, the 4080 or 4090 at all as the next gen are due for release in January and are set to be a substantial upgrade.
Why pay 1100 now for something that's going to be outperformed by the 5070 next year ar 700 or thereabouts.
chrand52
All good points, thanks guys appreciate the feedback
Wouldn't listen to spyder about the 5x series, why wait for january and pay 2 to 3k for a 5x series when most specs are rumoured to ne close to the 4x series only the 5090 out preforms all, also nvdia stopped maxing the 4x series to ensure people buy the over priced 5x, I'm picking up a new gaming rig end of the month with a 4090 and ryzen 9800x3d.
As for your build I'd get a different case drop cpu down to the 7800x3d (as you are a gamer not a video editor) 9800x3d is good too but only paired woth 4080 or 4090. try save and get a 4080 super drop ram down to 5700mhz for the sweet spot and if u can pick up the
ASUS® ROG CROSSHAIR X670E HERO​
Motherboard, avoid anything that says "gaming" that's just a gimick.
Need any more advice always happy to help Been a pc builder for 26 years
What are you talking about, since when is an x80 tier card 2 or 3k? Seriously, there’s pulling something out of the bag and just talking drivel.
If you really are a PC builder of 26 years then you’ll understand generational gains, so a 4080 will be outperformed by a 5070
So you’re saying a 5070 is going to be over 2k?
this literally happens every generation in the high end models, no idea why you think this is odd?
There is no such thing as 5700MHz RAM either? And if you’re talking about Ryzen, 6400MHz has widely been hailed the sweet spot for performance but 6000MHz for value
Me calls noob who has zero clue.
The fact you’ve been signed up since 2016 and this is your first post as well, thanks for such generous contributions 🤣
Ekans2011
I would also point out that the 7800X3D has been out of stock for a long time (and will most likely never be seen again); AMD will release the 9800X3D next week at a slightly higher cost than its predecessor ($30 or so), so I believe choosing a Zen 4 CPU is not a smart move when you can get a Zen 5 CPU for around the same price.
The MB you've suggested is extremely overkill for the OP's needs.
The new X870 chipset (essentially a B650 with USB4 and WiFi 7) is more than enough for a gaming system.
The 5000X is an excellent case in terms of airflow, build quality, and design.
chrand52
I’m just gonna bookmark this thread for when benchmarks and prices are released in January, always love saying the line “Told you so!”
Sorry was ment 5200 ram also chasing the gpu trend isn't good the 4090 and 4080 are decent enough for what this person needs as a budget. Also "While there is no formal launch pricing information just yet, we’d expect it to be above the $1,599 asking price of the RTX 4090." 4090 cheap end 2k so 3.5k? Go check a few sources that where right about the 4x series. 6400mhz ? Sweet spot ? Go Google 6400mhz mhz ram crashing in games, had a friend send a pc back here where they had to underclock the ram still had issues and he went to 5200 🤷‍♂️.
My first post ??? Really can't think of anything other to post 🤣
Ekans2011
Yes, AMD stated that this is the sweetspot frequency for their Ryzen 7000 and 9000 processors.
I never mentioned a 90 tier GPU anywhere at all, so that’s a completely irrelevant thing to bring into the conversation.
I Never mentioned a 90 tier GPU so that’s was a completely irrelevant thing to bring into the conversation.
4090 was regularly seen at £1600 when it was actually made, it wasn’t £2k until later on in the lifecycle mainly when they’d stopped manufacturing it.
In Wukong, the 4080 can barely achieve 60fps at 1080p, and there are now a few games like that,
And it’s not just me suggesting people wait, it’s across professional viewpoints as well, and it’s not specific to the 5000 launch, it’s the same at the end of any generation once they stop production and pricing increases (skip to 1:42)
Oh, and has no clue about hardware either! What the hell is a “4x series”? Do you mean 400 series mobos that are on DDR4 anyway? If you’re trying to overclock DDR4 above 3600MHz no wonder it’s failing! Doesn’t make any sense.
If you don’t understand how to achieve stability on a 600 or 800 series board at 6400MHz then you shouldn’t own a gaming pc as you’re severely lacking in skills required to use it
Just because you have no clue how this works doesn’t mean you need to hand out uneducated and false guesses to people out of ignorance.
I've got Corsair Dominator Platinum 6400MHz that has been stable since I bought the PC...and recently noticed it had a second 6600MHz profile that I've switched to. Still stable in games and Adobe Creative Suite.
Maybe consider another carer career choice, other than forum troll then (I think that role is already taken) ;)
t_dawg
Wow this thread escalated quickly 😅. I think I’m going to stick with the original advice and go with my build, built for 1440p UW. Thanks again guys.
You have to come down hard on trolls posting stuff they have absolutely no understanding of.
I own a wide aspect ratio (superwide) 1440 and a 4k gaming monitor. since going to wide aspect I’ve never gone back to standard, even at 4k, the immersion that ultrawide / superwide provides is far more valuable than going up to 4k imho
