Help with valeon laptop build
TomYou
Hello forum! Hoping someone will be able to assist me with my enquiry.
Just found this website today after looking for some 17inch laptop options as there doesn’t seem to be much in stock choice for laptops of this size for gaming.
After specifying a potential build that can be seen in the attached photo I have some questions about it and wondered if anyone who had a valeon or knows more about it might be able to help.
How are the thermals in the chassis? can it be undervolted and overclocked?
is the qhd screen good quality? what is the nits brightness rated at? couldn’t see the rating in the specs. Also i had to return a M17 R3 144hz 1080p laptop as the backlight bleed was unacceptable for 2k spend.
is my configuration going to be able to run games at good fps at 1440p?
can the laptop be upgraded with ram and ssd in the future?
thanks for your help in advance!
Bhuna50
The Valeon only appeared on the configurator last week so it is unlikely that anyone has had one delivered yet to be able to advise how good it is etc.
Regarding upgrading, it is likely that you can upgrade the SSD and the RAM later on but you will be best asking PCS directly. Similarly if there are no details in the detailed specification regarding your question on brightness then ask PCS.
finally, if you want advice on your spec, follow the link that @barlew posted above.
TomYou
Thanks for your help guys. Didn’t know the laptop was so new and i’ve reposted the thread in the right area using the link. Thank you
